gas tank leak
gas tank leak
is there anything other than the sending unit assembly that could leak on the top of the fuel tank?
i only gtet a gas smell when i launch it hard or make a hard right corner,& only over 1/2 tank,and the top of the tank is damp, but not around the sending unit, i already pulled that out and resealed it twice. im assuming my tank has a hole in it unless theres maybe a retarded fitting for the vent or something.[&:]
RE: gas tank leak
the thought crossed my mind, here i go workin on the f-ng thing more than driving it again.
now where in the hell do i find a gas tank for a 93 AWD...
i suppose ill pull the tank out tomorrow cuz i cant find the leak, maybe ill dry it out good and let it sit for a week then weld it shut.
RE: gas tank leak
the good part is it dont leak bad enough that it even drips off and the sides of the tank wont even get wet, its just a little on the top in front of the sending unit. if that cover isnt over the hole it reeks like hell inside the car though.
RE: gas tank leak
cuz the top of the tank is wet genious. and it only leaks whens its over 1/2 tank and i launch it or make a hard right corner. you want to come look for yourself?
im just wondering if anything elses has a seal into the tank (return line or vent) other than the sending unit assembly.
