15 lbs of boost with out boost controler
as far as i know this is not normal but the car still runs fine and fast all ive got is a cat back , intakeand a tubeing kit i have put 3 diff boost gauges on it to check and some times when its cold it hits 16 psi what do yall think
RE: 15 lbs of boost with out boost controler
Ya sounds like the wastegate.. My friends GSX did that on a 14b turbo, and his was hittin 20 psi if he got on it.. Once he got a new wastegate it was runnin back down around 12...
ORIGINAL: anko_kun
no bcs romoved and a stock turbo ill the lines are good car as far as i know has never got hot at all
