4G32 Crankshaft same as 4G37?
Hi, I have a 4g32 engine from a Bobcat that spun a rod bearing and chewed up the crankshaft. I've searched all over the internet for a 4g32 crank to no avail. What I have come across is that the block to the 4g37, 4g33 are the same as the 4g32 only with a larger bore. My question is, would the crankshafts be interchangeable between these engines? My crank has the 5 bolt holes for the flywheel like the 4g33 and 4g37. Would a crank kit for say a 1993 Eclipse with a 4g37 fit a 4g32 engine block? Thank you for any help, I greatly appreciate it.
