91 Eclipse oil leak!
Ok guys. I have a 91 GST with a small oil leak. My question is, is it supposed to leak? I know it may seem like a dumb question but it is leaking out of a small hole in the valve cover that is supposed to be there. It is on the front of the valve cover and looking at the engin it is on the right side. I say the hole is supposed to be there but I am really not sure. I replaced the valve cover about a month ago and the old one had the same hole on it.
Anybody have any ideas?
Thanks,
Stephen
Thanks,
Stephen
RE: 91 Eclipse oil leak!
Ok, got a pic, here is the link
http://img77.photobucket.com/albums/...t=51e68d0e.jpg
It is on the right front by the timing cover...hope the pic helps.
Thanks,
Stephen
Thanks,
Stephen
Thats your prob... it leaks because it is a hole into your vavle cover... oil is gonna come out... either run a small hose back into your intake or put a breather on it. considering you have a gst though... put an oil catch if you route it back into the intake. oil inside your intercooler isnt a good thing.
