ABS Light is ON ?
ABS Light is ON ?
Hi,
i own Eclipse 96 GS.
We checked sensors and are OK, my mechanic said, that must be problem in electronic or computer (not sure).
Does anyone know or had same problem ?
P.S.: Brakes work but ABS not
Best Regards
Best Regards
RE: ABS Light is ON ?
on many vehicles, the "ABS" light signifies some problem with the braking system, including a low brake fluid condition. if your brake pads are very thin, and youre running on rotord that are well below man. spec., it can draw enough brake fluid out of the resevoir to trigger the low fluid "ABS" light.
The Haynes manul says to look for the following:
1 Check the brake fluid in the reservoir
2 Verify that the computer electrical connectors are securly connected
3 Check the electrical connectors at the hydrolic control unit
4 Check the fuses
5 Follow the wiring harness to each weel and verify that all connections are secure and that the wiring is undamaged.
I would start with one and four but the mechanic should already have checked these. Also did the mechanic read the cars codes?
4 Check the fuses
Id like to think that more computer control would help find problems faster but some days i wish there was non at all. Keep it simple spark, gas, air. Maybe thats too simple. Maybe i was born 30 years too late.
