Bad or not bad?
Old 09-26-2006, 09:58 PM
agallardo's Avatar
Default Bad or not bad?
Hey guys. I put a little oil in today because i was a little short. But anyway, I took it for a spin, and I forgot to put the cap back on, so yeah... i spilt oil around that area. Is this bad? I spent the last 2 hours cleaning it, and there might be a little left, but do you guys think this is bad? It got around 2 injectors, around some spark plug wires, around the intake manifold, etc. Around that area. What do you guys think? Is it safe to drive still?
Old 09-26-2006, 10:02 PM
Default RE: Bad or not bad?
any left over will burn off
Old 09-26-2006, 10:25 PM
agallardo's Avatar
so nothing bad?
Also, i pulled off my spark plug wires and and the "metal piece" came off and stayed connected to the spark plug. But I just took the spark plug wire and connected right back. Is this bad? I cranked it up and it seemed fine and turned on fine. So what do you think about this?
Old 09-27-2006, 01:59 AM
agallardo's Avatar
anyone.......
Old 09-27-2006, 11:49 AM
agallardo's Avatar
Please help. I am not sure if I should drive my car like this???
Old 09-27-2006, 12:08 PM
i think your fine
Old 09-27-2006, 02:08 PM
agallardo's Avatar
Even with the spark plug wires?
Old 09-27-2006, 04:39 PM
nothings going to blow up if you got alittle oil on it. probably the worst thing thats going to happen is you're going to smell burnt oil for alittle while. drive it easy for a bit, and if it sputters, misses, get some new plug wires.
Old 09-27-2006, 04:48 PM
agallardo's Avatar
Awesome... Thanks guys. Appreciate the help.
Old 09-27-2006, 10:14 PM
Sanguinius's Avatar
If you're really paranoid spray a little cleaner in there something citrus or whatnot (NOT carb cleaner it WILL eat rubber seals like it was a starvin etheopian). Then rinse with a little water and allow to dry a bit before driving again (Or cover the alt and you'll be fine after that anyways lol).
Quick Reply: Bad or not bad?
