Barely starts and then dies in 5 Seconds
  #21
Old 08-11-2007, 06:35 AM
Bigfatso's Avatar
Default RE: Barely starts and then dies in 5 Seconds
I have Figured out how to align the timing marks and get everything back together. I pulled the plugs and did a compression test. Here are the numbers (front left to right, Facing the engine):
100 | 150 | 125 | 150
1 2 34 ( I think thats how they are ordered)
Anyhow if 1 and 3 would both have been 125 Psi. I would feel good enough to drive it. However a 33% drop in pressure from Highest to lowest is too much to be able to explain away with engine wear. Am I correct in the understanding that 1 & 3 travel up and down together? If so, then I would say some valves got smacked around a bit for sure.
Anyone Know where I can get a good used head for a turbo car????
  #22
Old 08-11-2007, 08:10 AM
silvercoupe97's Avatar
1+3 are really low.
Are you sure you did it correctly? Here's a reference..
http://web.archive.org/web/200611061...ompression.htm
http://web.archive.org/web/200611180...s/leakdown.htm
I believe it goes 1+4 and 2+3. Something isn't right with your figures bud.
  #23
Old 08-11-2007, 08:11 AM
Also, from left to right it goes like this...4-3-2-1.
  #24
Old 08-11-2007, 01:25 PM
Bigfatso's Avatar
It was late and I did only the dry test and didn't pull the MPI fuse. I Cranked the engine 6 times each and did the test twice for each cylinder. It is about 100 degrees outside now and I was soaked from sweating. It was a real pain in the tailpipe getting the auto tensioner adjusted properly without the special DSM tools and I just wanted 30 minutes of Air conditioning before I went to bed. I plan on doing the wet test sunday afternoon when its going to be 4,000 degrees outside. I have an adaptor I can use to pressurize the cylinders, If its quiet enough outside I should be able to hear where the air is escaping.
Again thanks for the inputs.
  #25
Old 08-17-2007, 04:56 PM
Bigfatso's Avatar
Finally found time to do a "wet" test. cylinder pressures went up across the board. 200 | 200 | 180 | 200. I'm going to order some parts and put it back together.
link988
07-17-2011 04:58 AM
mobetta
09-28-2009 12:50 PM
rexbd
01-29-2008 07:18 PM
muddyjoe
07-09-2005 10:54 PM
Quick Reply: Barely starts and then dies in 5 Seconds
