++ Boost ++
++ Boost ++
Alright... I want to boost my car... I would like to do it the cheapist way possible without having a lot of problems. What would I need for a moderate turbo charge? And what can I use off another eclipse. I got a 2.4L 98, I know the manifold will bolt up... what else could i use?
RE: ++ Boost ++
down pipe, rear exaust off a gst. smic, bov, ic piping, you would need to get a oil line kit though, and I would recomend getting a 16g with the waste gate set at 10 psi to start. you will also need a fuel system I recomend getting a sfmu ss hose kit setup w/ return line and a fuel press gauge either inline or in cab. Also injectors for running over 10 psi, safc to controle them, a 225lph walbro... that should be about it, you may need a new clutch after all of that and some abuse but taht should have you sitting pretty.
RE: ++ Boost ++
ORIGINAL: EMonz57
if you go cheap you will break the car... boosting is never cheap unless you cut corners
RE: ++ Boost ++
ORIGINAL: EMonz57
That's very true..............U should save up and buy a kit speificly made for ur car.........because they will have been tested and will have solid dyno numbers for u.
