CAR WONT START!!! HELP
i just got a new intake (not instaled yet), and MY CAR WONT START!!!
there is absolutly no power to the starter or anything else in the car... music works, all other electronics work... but key in the start position... power gets cut off, and car doesnt start... there is power in the ON position... but not in the START....
what do i do, how do i fix this?
please all the info you can give me!!!
THANKS in advance
Serge
THANKS in advance
Serge
RE: CAR WONT START!!! HELP
ORIGINAL: edgeofsane
Is your mass airflow sensor hooked up?
Does the cel come up when you have it in the on position? If it does then it sounds like their may be a short some where. If you cut/spliced any wires anywhere check them out. Good place it start is if you put a new hed unit in the car. Also try resetting the car by removing the neg batt terminal for a few min. When ever you install a new part you should always reset the ecu. I would say maybe it was the instlation but thats a very simple install and its hard to make a mistake.
Ok.. it could either be the solonoid or the starter. When you try and start it do you hear a little click? Or no click? If its no click then its your solonoid..if you do hear a click then its the starter
My car won't start either..it was fine 2 days ago..but then it rained..and it was just sitting in my driveway all day...the next day it doesn't start..my radio and electronics work fine. My engine even begins to start but then just stops.
