Carbon Build up - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 11-12-2005, 07:34 PM
Default Carbon Build up
Hey guys whats the best/easiest way to clean the carbon outta the combustion chambers? Ive heard of letting them soak in mopar combustion chamber cleaner but was wondering if anyone had found another way of cleaning them. The reason i ask is i was cleaning my plugs today cause my mpg was suffering a little and decided to look inside while i could. three of the piston tops were flat black and the fourth or #1 piston was about half black and half of it i could see the top of the piston shining back at me. was just wondering what you guys thought. 98Gs-t w/108xxx miles
Old 11-12-2005, 08:39 PM
Default RE: Carbon Build up
There are treatments that can clean some of it. bu I don't think you'll EVER get them ALL clean. I'd worry more about the carbon buildup around valves and seats then on the pistons.
Old 11-12-2005, 10:18 PM
sea foam
Old 11-12-2005, 10:27 PM
Valveoline
Old 11-12-2005, 10:48 PM
Plain ol commercial decarb service kits can be used to introduce a chemical treatment into the intake while the engine is running to blow the carbon build up right out of the enhaust. It's best to do it when the engine is absolutely warmed up/hot. It is effective on most vehicles unless the carbon build up is super thick. I do this all the time at work especially with vehicles that fail smog due to high NOx emissions.
Good Luck!
Joel, CA
Old 11-12-2005, 11:15 PM
Yeah I used to use the Valvoline 3 part service kit. 1 part went into the gas the 2nd was a cleanser spray that decarboned the intake/butterfly valve, and the 3rd part was a chemical that went into the intake via the power brake vacuum line that cleans the valves and cylinders and gets all the crap blown out the back end. The final chemical takes a good 45 minutes running to go through and when you drive the car afterwards it's like crop dusting the area LOL... It leaves a HUGE cloud of smoke behind until the chemical is fully blown out of the system.
Old 11-13-2005, 03:35 PM
Where can i get something like that sang? Autoparts store of do i have to have the dealership do it for me?
Old 11-13-2005, 07:26 PM
It will be something that will likely have to be done by a shop. It's a professional grade cleaner. You can get weaker cleaners that you use either on the intake or in the tank at the auto store but the 3rd part that gets sucked in by vacuum lines won't be available.
Old 11-13-2005, 09:52 PM
Thats what i figured but thankx anyways.... im not so worried about the pistons but that is just another sign of carbon build up on the valves and such.....oh well[&o]
Old 11-14-2005, 02:09 AM
Most shops charge one hours labor ON TOP of the actual part (roughly around $50 for parts). You should be able to purchase the part alone and do the labor yourself. You'll just need something to regulate the amount of the solvent that is ingested into the intake. Good Luck!
Joel, CA
Thread Thread Starter Forum Replies Last Post
Build Sheet/Manufacturer Info? Skiddy General Mitsubishi Chat 9 05-08-2016 11:53 PM
How to build a track terror 420a: By slow420a Patrick Eclipse Frequently Asked Question Section 1 04-26-2016 03:07 PM
want to build a 500+ hp setup in my galant, need ideas! sic98galant Mitsubishi Galant 1 10-18-2005 04:02 AM
Looking to build a very fast GSX dieselpilot69 2nd Generation 3 12-31-2004 07:07 PM
Woman aboard, I build and race ... hereclipse New Members Area 8 10-13-2004 06:36 PM
Tags
2004, buidup, build, carbon, chamber, clean, cleaner, combustion, eclipse, engine, gt, intake, mitsubishi, mitsubushi, whats
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
