EVO 8 engine/tranny swap into 1G - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 02-24-2005, 06:20 PM
Default EVO 8 engine/tranny swap into 1G
Well, I did some searching and was coming up with much of nothing. I just bought a beat-up old 1990 Eclipse GSX 5spd. Now everything runs/works properly, but it needs new clutch and it cant idle for too long cuz oil gets in the valves or something like that. So I was thinking if it is possible to put an EVO 8 Engine and Tranny Swap or 3000GT Vr-4 Engine and Tranny Swap or Just stick with the engine I got build it up, possible larger or different turbo, other performance parts, etc. I would just like input as to which would be the best choice, seeing that money is not readily available.
Old 02-24-2005, 07:37 PM
Default RE: EVO 8 engine/tranny swap into 1G
I would just invest money in a 1st gen long block, replace all internal with forged internals, that way you dont have the threat of crankwalk as you do with a 2nd gen. You can make a 1st gen block handle a much larger turbo and push 22+ lbs with a nicely built long block. Then of course, you want to get a oversized valve job.
Old 02-25-2005, 03:18 AM
whats the difference between a short block and long block. So what is all needed to convert it to a long block.
Here is list of some mods I want to do:
Forged Internals
Valve Job
Uprgraded Turbo and fuel system
Upgraded Clutch/Flywheel Package
Anything else will tranny be able to hold.
Thread Thread Starter Forum Replies Last Post
Engine Swap Complete - 2.0 SOHC into Eclipse lars 1st Generation 0 07-16-2007 12:07 PM
evo 3 swap into 95 gst 95 gst 2nd Generation 7 02-11-2007 07:23 PM
(NEWBIE) tranny will not shift into overdrive? diskretephx New Members Area 3 02-02-2007 11:15 AM
evo engine into gsx???? krentigrwoodz 2nd Generation 7 05-06-2005 07:44 PM
94 TRANNY ONLY GOES INTO REVERSE SOMEONEWITHNOSINCE 2nd Generation 1 08-18-2004 07:43 PM
Tags
1g, block, difference, dsm, eclipse, engine, evo, longblock, mitsubishi, parts, sale, short, shortblock, swap, swapable, tranny, whats
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
