Help!! 95 Eclipse Smells like Antifreeze - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 09-13-2007, 08:01 AM
Default Help!! 95 Eclipse Smells like Antifreeze
Hey guys..i need some help here...take it easy cause im a girl!...I just got a 95 Eclipse GS...it seems to have a strong smell of antifreeze inside the car & my check engine light is on...I check the passenger side floor..its not damp...so i dont think it could be the heater core...the oil in the car is clean..nothing unusual in the oil...nothing leaking out of the motor of the car..or around the heads...and nothing leaking on the ground...one time it did seem to kinda lug up a hill...but it only did it once...does anyone have any idea what could be going on here??? or has anyone has this problem? thanks!
Old 09-13-2007, 08:04 AM
jason clipse's Avatar
Default RE: Help!! 95 Eclipse Smells like Antifreeze
did u check the antifreeze level? u didnt mention it
Old 09-13-2007, 08:44 AM
has your car overheated at all. Bring the car to autozone and get that CEL scanned. Any white smoke comming from the exhuast. If you can smell it in the car then its probably the head gasket. Especially with a 420a
Old 09-13-2007, 09:08 AM
well just cause the floor isnt damp doesnt mean its not the heater core, i just replaced the heater core on my lumina... most cars now-a-days have a tray that sits under the heater core with a "hose" that leads outside usually through the firewall... when i pulled that off it had a big puddle of antifreeze in it... i'd almost have to say that that is your problem if you're smellin antifreeze in the car
Old 09-13-2007, 10:49 AM
I checked all around the motor i dont see anything leaking anywhere...i thought if it was a head gasket or the heads there would be something leaking from around them....and i did check the anti-freeze level...everythings all good....and it hasnt overheated...my temp gauge stays normal..and it isnt blowing any smoke..i was just wondering if the anti-freeze smell has anything to do with the check engine light....or if it would have anything to do with it lugging up a hill (it only did this once)...would the heater car trip the check engine light?...and are there any other ways i can tell if this would be a problem with the heads/ head gasket?...i took the car to autozone...they keep saying nothing is wrong, its currently in a mitshu. shop right now...they are supose to be calling me & letting me know whats up..but ive had it to 3 other shops & they cant seem to find a problem....i think no one know whats going on or what their doing for that matter....any thank you so much for your replys!
Old 09-13-2007, 11:12 AM
Hmmm Autozone says nothing is wrong even when the check engine light is on? Tell them to scan it and get the code. There cant be a check engine light without a code...
Well one major sign of a headgasket is big clouds of white smoke from the exhaust.. .and a white goop under the oil cap.
It doesnt sound to me like this is your problem. Just out of curiosity, what makes you think its antifreeze? It usually smells sweet when its burned... Possibly its something that has previously leaked out and is touching a hot component?
Sometimes the radiator cap leaks when things heat up and pressure builds up... think that could be it?
Old 09-13-2007, 11:17 AM
could also be a stuck thermostat... which would mean your temp gauge wouldnt go up even if it was overheating... definitely get it scanned
Not thermostat.. the car would overheat right?
Old 09-13-2007, 11:21 AM
right, which could help explain the smell of antifreeze... but if it was a stuck thermostat, then her gauge wouldnt give any indication to it overheating... just a thought
Old 09-13-2007, 11:29 AM
I guess your right... thats possible. Do the fans ever come on? Do you ever notice any leakage around the radiator cap?
Thread Thread Starter Forum Replies Last Post
2003 Eclipse out of Antifreeze but no apparent leaks. Milesgolfer 3rd Generation 7 01-22-2012 05:52 PM
losing antifreeze 2003 eclipse 4cyl no leaks wild-wood Everything else 2 05-12-2011 05:54 AM
My 03 outlander smells! Xadion Mitsubishi Outlander 1 01-02-2008 07:08 PM
Antifreeze... agallardo 2nd Generation 2 10-31-2006 03:54 PM
BAD antifreeze leak!! 97redEclipse0010 2nd Generation 5 04-08-2005 01:38 AM
Tags
antifreeze, burned, car, engine, fluid, gauge, hot, mitsubishi, montero, normal, overheating, radiator, smells, smoking, sport
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
