Help! 98 eclipse rs wont start
Hi everybody. My girlfriend has a 98 eclipse rs automatic, she left it parked for about a week and when she tried to start it, it fired up for a few seconds and died. The first thing I checked was to see if it had spark. Car fires but it's not getting any fuel. I narrowed it down to what I thought was the fuel pump but I replaced it and it still wont get fuel. I would imagine that her ecm controls the fuel or is there a fuel pump relay? Has anyone else had this problem? Is there a fuel pump check connector or anything? Any help would be greatly appreciated. Thanks, Damon
RE: Help! 98 eclipse rs wont start
i cant answer any other questions.. all i know is that there have been like 10 (no exaduration) people on here this month alone asking the same question and each one with the same fix. Thats all i can tell you.
No, it doesn't even start for a second now, just turns over. The only way it will start is if I spray starting fluid into the throttlebody. Like I said, it's getting spark but the fuel pump wont prime or anything. I checked both fuel pumps by hooking them directly up to the battery and they both work so I'm really at a loss here.
Ok... possibly not what i thought. Thats ****ed up man... have you tried reseting the ECU? Just dissconnect the battery for an hour and reconnect it and try and crank it over. Check the solenoid too!
PS... alrite dude im goin to bed. Its like 1:30 UK time.
that happened to me when I left my car sit while i was at basic training. I don't know why, but when I disconnected the fuel line going into the fuel rail and reconnected it it finally started. See if that works for you.
