Need a liitle help please. brake lights wont turn off - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 09-23-2006, 11:49 AM
Default Need a liitle help please. brake lights wont turn off
I got home last night and apparently after i turned my car off the tails lights stayed on all last night. i went out today and checked the fuses , checked the emergency brake, checked the brakes. the turn signal works as well as the hazards but the brake lights including the center light stay on, does anyone have any idea? its a 96 eclipse spyder, thanks
Old 09-23-2006, 02:04 PM
Default RE: Need a liitle help please. brake lights wont turn off
turns out it was the brake switch that the brake pedal pushes on it screws up/back which adjusts the pressure. adjusted it and good as new.
Thread Thread Starter Forum Replies Last Post
dashboard lights wont turn on. need help crapanotherday 2nd Generation 0 03-07-2012 10:42 AM
96 eclipse spyder lights won't turn off kshollywood 2nd Generation 2 01-14-2009 06:13 PM
Brake Lights Quit Working Need Help Please Pokerdude Mitsubishi Montero & Montero Sport 2 10-22-2007 08:31 PM
What's common for Turn signal, brake, battery lights? ricketter 2nd Generation 6 08-17-2006 03:21 PM
no reverse lights and turn signal won't turn off dornstar 2nd Generation 5 05-22-2006 04:58 PM
Tags
95, 96, brake, eclipse, galant, lights, mitsubishi, mitzibushi, montero, shut, stay, switch, tail, turn, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
