New Alarm, Old Alarm
Old 02-24-2008, 12:44 AM
victim619's Avatar
Default New Alarm, Old Alarm
I got my viper alarm! I love it! my old alarm keeps going off at random! Most the time at night when im asleep like 2am to 4am. I need detailed directions on how to remove this.....please. thanks, 99 spyder gs
Old 02-24-2008, 03:12 PM
victim619's Avatar
Default RE: New Alarm, Old Alarm
anyone know how to remove the OEM alarm???
Old 02-24-2008, 04:24 PM
50ul }{4ck3r's Avatar
i posted a fix for this
HERE U GO BRO!!!
This guide works for all models of the 97-99 Eclipse..and from what i understand 96 and later have different wiring colors and possibly different component locations so you could use this as a guideline only.
First things first locate your fuse panel under your dash and remove the 10A fuse labeled Anti- Theft and save it for a spare.
Second locate the relay box under your dash next to your hood release latch
Third...remove the two 10mm bolts holding the bracket under the dash for ease of access to the rear of the box. Locate the Theft - Alarm Horn Relay..remove it and sell it on Ebay cause you won't need this anymore. Next turn the bracket to expose the rear of the Theft - Alarm Starter Relay
Fourth.. Your looking at the rear of the Theft - Alarm Starter Relay right?
There should be a black wire with a blue stripe clip it and and inuslate the loose wire with electrical tape. Now do the samething to the Light green wire with a black stripe.
Fifth.. Bolt the bracket back into place and now its time to test it!! Roll down your window and remove your keys from the ignition. Now lock your door with the button on your door and shut it. The security dash light that comes on when your system is armed should come on. Then reach in and open the door with the interior handle. If your alarm went off double check your work! If it didn't then good job keep up the good work!
Old 02-24-2008, 04:55 PM
victim619's Avatar
I understand everything but the 4th step.......
Old 02-24-2008, 05:53 PM
victim619's Avatar
which one do I pull?
Old 02-24-2008, 05:59 PM
victim619's Avatar
My fuse box
My fuse box up close
Old 02-24-2008, 06:10 PM
victim619's Avatar
which wires am i looking for also for the next step. I already had my viper alarm installed so some wires are in electical tape ahh im confused.
Old 02-24-2008, 06:35 PM
im not really sure
i havent had a chance to do it to mine yet!!!
Old 02-24-2008, 06:39 PM
HERE U GO BRO!!!
Old 02-24-2008, 07:23 PM
victim619's Avatar
ORIGINAL: Manny1993
HERE U GO BRO!!!
that was odd.....anyone else? TE?
Quick Reply: New Alarm, Old Alarm
