stalling while running
everytime i press the clutch when im moving the engines rpms drop to about 200 then come back up, but when i accelerate hard then get on the clutch the engine just stalls in the middle of me driving, is it a problem with the idler or what, i almost went through an intersection cuz i was trying to make a right turn and the car turned off when i got on the clutch what is the problem?????!!!
RE: stalling while running
thats a small symptom of crankwalk and an almost definite symptom of a vacuum leak. However, he does not have crankwalk because you would have other symptoms first. How do I know? I have had it. And I have read everything there is to know about it.
Your car does not stall after left/right turns, the clutch sticks to the floor after a left turn.
You would also hear a loud clicking when you press the clutch in while idling.
the stalling only comes after these symptoms and i would not even worry about cw unless you notice the clutch sticking to the floor, thats the #1 sign.
o yeah i know its not crank walk, i checked some hoses a few of them seem a little loose and its been better so i guess it was just that, i might have a leak in one though i gotta check more. thanks alot
ORIGINAL: patsevo8
Look cowboy, not all symptoms of walking crank are the same. I was doing a 1/4 mile run when I had it.
Just because he's not hearing clickity clank, doesn't mean he doesn't have it.
kainrath
08-21-2006 06:11 PM
