Po303 misfiring, power loss, and rough low rpm - Mitsubishi Forum - Mitsubishi Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 04-19-2008, 05:06 AM
Default Po303 misfiring, power loss, and rough low rpm
Greetings,
I am hoping that someone can help me with the diagnosis of my 1999 Mitsubishi Eclipse GSX.
OBDII reports diagnostic code Po303 - misfire in cylinder 3
Fairly smooth at idle and high revving when out of gear
Revving is always rough at low portion of rpm curve
Misfiring at low rpms when in or out of gear
Rough with power loss when in gear, especially under load or with heavy throttle (from start, uphill, or when floored)
Will drive almost normally if I'm _very_ gentle with the gas pedal
Flooring it when in gear results in deep low tone, rough vibration, and flabby power
Can anyone make a suggestion based on my symptoms?
Thanks!
Old 04-19-2008, 09:34 AM
Default RE: Po303 misfiring, power loss, and rough low rpm
change your spark plugs and wires and that will probably fix the issue
Old 04-20-2008, 01:03 AM
Any idea whether it could be a fuel injector?
Old 04-20-2008, 06:41 AM
not really... its either that or the coil pack... trust the engineer
Old 04-20-2008, 09:43 AM
dsm1990gsx's Avatar
Injectors and coilsusually aren't a parts that fail often, listen to TE and change your plugs and wires.
Old 04-20-2008, 10:01 AM
I had the same thing.. Except it was misfire on cylinder 1.. Ended up being the spark plug wires.
Old 04-20-2008, 02:46 PM
Great! I already ordered plugs and wires, but just wanted to make sure in case other parts might be necessary.
Old 04-20-2008, 07:39 PM
And the winner is... Spark plug wire #3
Changing plugs and wires solved the problem. Thanks!
Old 04-20-2008, 08:43 PM
yeah i had the problem of oil getting into my number 2 cylinder due to a torn sparkplug boot, andwas causing a bad misfire, so finally i replaced the wires, cleaned the oil, ran like a champ.
Old 04-20-2008, 09:04 PM
glad to hear it.
Thread Thread Starter Forum Replies Last Post
00 eclipse gt misfiring in low rpms CODE P0300 WackJobRacing27 3rd Generation 2 08-19-2013 07:47 AM
00 eclipse gt misfiring in low rpms WackJobRacing27 Everything else 0 08-18-2013 03:14 PM
Loud tapping, low compression in no. 6, misfiring Buzzer_k Mitsubishi Montero & Montero Sport 5 07-22-2013 02:00 AM
Power loss after tapping into stereo power wire. jdohe Interior Wiring 0 12-12-2010 08:00 AM
Mitsubishi pajero low idle,loss of power, often stalling Fullysickmitsu General Mitsubishi Chat 0 12-04-2007 07:52 PM
Tags
2001, 420a, 6, cyl6, eclipse, galant, loses, misfire, mitsubishi, montero, po303, power, rough, runs, sport, uphill
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
