Runnin Lean??
Old 04-08-2006, 01:50 PM
a2rht930's Avatar
Default Runnin Lean??
p0170 Fuel Trim Malfunction. What causes it,and how do I fix it.
Old 04-08-2006, 05:22 PM
Default RE: Runnin Lean??
could be one of two thing i think. 1) there is a leak and the cause could be the valve cover gasket or 2) You could have bad air flow through your MAF. Those are just a couple. there may be more. Is this the only code that your getting?
Old 04-08-2006, 11:27 PM
a2rht930's Avatar
yep
Old 04-09-2006, 01:13 AM
Joel_CA's Avatar
Check for a manifold vacuum leak somewhere or some other source of unmetered air.
Joel, CA
Old 04-09-2006, 03:13 AM
Sanguinius's Avatar
Check your intake piping for cracks or rips, loose clamps. cleanliness of the MAF as well as the air filter. Let us know what you find.
Old 04-10-2006, 12:46 AM
eclipsed4u's Avatar
also get the cat and the o2 sensors checked(if you still have a cat). faulty readings from bad o2 sensors can make the ECU think that there is a problem with the a/f ratio.
Old 04-10-2006, 12:50 AM
ORIGINAL: eclipsed4u
wont that ussually throw another code in there too though. Ussually i think you will get the fuel code but you will also get the 02 code for bank 1 or bank 2....right?
Old 04-10-2006, 01:04 AM
eclipsed4u's Avatar
ORIGINAL: TheEngineer
sometimes, yes. but i know that there is not a code for a bad cat, and it also throws similar codes. when my cat went bad, it threw P0171 and P0174 codes.
Old 04-10-2006, 01:13 AM
ok ill agree on the cat but not the o2's being a possible problem. But because its only throwing that one code i am going to still guess a leak
ilb2fast4u
11-01-2008 07:07 PM
asphalt_pimp
01-29-2008 09:37 PM
asphalt_pimp
10-17-2007 10:15 AM
awd92tsi
05-29-2007 12:51 PM
hosrom
03-31-2007 08:28 PM
Quick Reply: Runnin Lean??
