pretty sure its the clutch
Old 12-06-2007, 11:11 PM
Gstfat's Avatar
Default pretty sure its the clutch
so my car grinds 3rd sometimes,i have a stage 3 clutch no name brand,my tranny good so heres my question,what act clutch should i get for my 2g gst,imma do like 300-350 to the wheels,is the act 2100 any good for that,but my setup right now is at about 230hp,would the act2100 still be good for that setup,and should get a light flywheel?
Old 12-07-2007, 12:24 AM
Default RE: pretty sure its the clutch
First of all I don't think that it sounds like the clutch, if it disengauges then it shouldn't gring, that sounds like it is the tranny becuase all the clutch does is engauge and disengauge, if it is doing that then it shouldn't have anything to do with the clutch. But if you are going to replace it you should get a ACT 2600 with a street disc, go ahead and do the flywheel since you are in there.
Old 12-07-2007, 01:39 AM
Sounds like a syncro to me.
Old 12-07-2007, 02:17 AM
3rd gear seems to be touch on my tranny too, I don't know why.
Old 12-07-2007, 05:25 AM
x2 on the synchro..
I have the 2100 on my GST and It works great for mine.. Im prolly pushing somewhere between 300-350 to the wheels..
Old 12-07-2007, 04:17 PM
Gstfat's Avatar
cool man,so should i also replace the tranny fluid?
Old 12-07-2007, 04:21 PM
if it is the syncros you are going to have to tear it apart, it is definently not the clutch.
Old 12-07-2007, 06:37 PM
bestwiseguy's Avatar
Mine does the same thing in 3rd gear, and thats even after i put in a act 2100 lb clutch.
Old 12-07-2007, 07:47 PM
Ya.. Your gonna need to pull the whole tranny off, so your fluid is gonna come out anyways.. And if you find a way to keep the tranny fluid in there when you fix it.. Your doing something wrong!
Old 12-07-2007, 08:05 PM
not sure about dsm's...
but i know that vw trans grind when fluid is low or the wrong one...
might be worth a shot...
Quick Reply: pretty sure its the clutch
