Trunk won't open! - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 12-27-2008, 01:37 PM
Default Trunk won't open!
Hi all,
The trunk on my 1999 Eclipse has not been opened for over a year. A real pain especially when you have a flat. Key or inside release won't open. Any ideas how this can be opened from the inside? There are two holes near the latch on the inside, but I can't find anything that moves! Any help would be much appreciated!!
Old 12-27-2008, 02:55 PM
Default RE: Trunk won't open!
no dude i dont think there is a way to open up the trunk from the inside... whats wrong with it? frozen shocks? lock? whats up?
Old 12-27-2008, 04:28 PM
It releases with either the key or inside release, pops open a 1/4 of an inch then its like a safety catch or something catches and you can't open it the rest of the way. Used to be able to pull real hard and it would open, but not now!
Thanks
Later
Old 12-27-2008, 07:40 PM
Sounds like the struts are froze up. Youre gonna need someone to upen it up and replace the little strut things on the inside there. It should be all good after that.
Way to go Sk8, her name says "chick" in it, so you call her a dude, lmao.
Old 12-29-2008, 07:58 PM
My trunk does the same thing... what i do is put the key in the trunk lock, go and pull the trunk release inside the car then go back and turn the key to get it to open.. sometimes i have to try this once or twice but then it works..
dont understand why this is the shocks hold the trunk open fine and have no problems with it creaping down while open.
worth a try if it doesnt work maybe try having someone pull the trunk release while you are turning the key.... I think that its something in the lock not the shocks at all
Old 12-30-2008, 10:21 PM
i call girls dude sometimes haha force of habit. and yea it definitely sounds like frozen struts... those should be a fairly easy fix
Old 01-03-2009, 12:07 AM
i think johnnyred might be right.
ive got a 98 gs and if you pull the lever on the inside it only opens like a 1/4 of an inch, then you can go like lift up ont he trunk and it wont open, but if you pull the lever again you can open it, or you can turn the key and hold the key open and it opens.
but idk yours sounds more like strut problem..
Thread Thread Starter Forum Replies Last Post
'00 GALANT TRUNK WONT OPEN W/ KEY OR LEVER LITTLEPAULA Mitsubishi Galant 5 06-01-2015 03:48 PM
2001 Mont Sport—How can I open a closed hatch latch with door open? writersmark Mitsubishi Montero & Montero Sport 2 03-02-2014 09:29 AM
Trunk wont stay open nefarius60 Mitsubishi Galant 2 07-16-2010 03:53 PM
Trunk wont stay open...help! nefarius60 Everything else 0 07-05-2010 04:02 PM
How to keep your trunk open? Russianfart 2nd Generation 13 02-13-2008 06:40 PM
Tags
1999, 99, diamante, eclipse, forum, galant, inside, lancer, latch, mitsubishi, open, problem, problems, shocks, trunk, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
