Whats the diffrence???
if you take the valves and everything else out of a head so its just the metal from a 2.0 dohc turbo and to a 2.0 dohc non turbo whats the diffrence?? and the same thing with the block whats the diffrence??
im making a race engine and i have the non turbo but i want turbo. im replacing everything anyway but i dont want to do it to mine if theres a diffrence between the two.
RE: Whats the diffrence???
ORIGINAL: Jeffisdecentttttt
There is no difference. If theyre both the 4g63, its just the difference of a turbo being bolted on or not.
ORIGINAL: bagz
yea but i said if you take everything out. im replacing everything anyway so i should just get a non turbo right? because its cheaper
And sorry about the CAPS lock on my other post[:@] didnt know that I had the it turned on it was early lol
ORIGINAL: EMonz57
WRONG THE PISTONS SHOULD BE DIFFERENT. NON TURBO USES HIGHER COMPRESSION PISTONS OTHER THAN THAT THERE MAY BE VERY LITTLE DIFFERENCE. (THATS PROVIDING ITS A 1G NON TURBO 2.0)
o woops. i didnt see that he was talking about the block. i only thought he was talking about the head...guess i wasnt paying attention...
ORIGINAL: slow420a
the blocks are different. The n/a block has a different style oil pump routing though it making the oil pressure lower then a non turbo.... which is bad if you want to make high hp# I would recomend getting a turbo block if you going to build it.
