01 GT heater and coolant problems
I learned the hard way not to ignore the coolant on my Eclipse V6 GT. Now after numerous flushes and cleanings I have, what I believe is a clean cooling system. When doing flushes the heater would work kinda sorta for a while. Now it seems to be losing coolant and engine oil, along with the heater problem. I bought a back flush kit and performed the procedure to excess. Refilled with coolant and Bars leak fix. Anything I'm missing? Oh yes the heat is better on the passenger side.
K Todd I realize bars leak can cause problems if not used properly. The problem is still little heat the heater core lines are, to quote my son, "pi$$" hot in and out. This is under the hood and under the dash. The radiator is new, Thermostat new, and the coolant is clean as a whistle. I checked the heat cool mix door the actuator is moving and you can hear the door operate. Oh I only used half strength on the bars leak.
p4c0
02-22-2007 06:36 PM
