03 GTS Intake Manifold
The upper intake on this car is leaking on the side around the rod that the adjustible valves are connected to (I guess the VIC system) Do any shops rebuild these, or do you have to replace the whole intake manifold? If you have to replace it, does anyone know the best place to get one? Thanks for any help. (The finger in the pic is pointing at the valves in the intake that open and close, not where it's leaking -- arrow is pointing toward leak).
elecbluegst
02-09-2006 03:57 PM
