2001 Eclipse GT(changing the belt)
Old 05-23-2005, 12:56 AM
Sanguinius's Avatar
Default RE: 2001 Eclipse GT(changing the belt)
Belts aren't fun to change on these cars. But then again it COULD be worse. The older model Sentra's you have to remove a wheel AND a motor mount to change out the common belts(Not even refering to the timing belt just regular belts). Look at your tensioner pulley is it on a spring loaded arm? If so then there is likely a square hole which a 1/2" drive ratchet will fit in. Get the belt in place and then put the ratchet on to pull that pulley out of the way and slide the belt in under it. Seriously I'd have t actually look at the engine to see what you'd have to do.
Coqui_Mitsubishi
06-12-2014 10:05 PM
Maui4me
03-15-2014 03:36 PM
aviator79
06-22-2008 12:30 PM
jscar
08-01-2005 07:34 PM
TarProductions
09-30-2004 01:24 PM
Quick Reply: 2001 Eclipse GT(changing the belt)
