2002 Spyder GS No Spark on One Ignigtion Coil
Old 02-25-2017, 06:04 AM
nmiller67's Avatar
Default 2002 Spyder GS No Spark on One Ignigtion Coil
Having an issue with Eclipse GS Spyder 4G64 (2002).
The car will start and run great when it does start. I can drive it and no check engine light, I've had it checked for error codes at Autozone and nothing comes up.
The engine turns over like it wants to start and i can usually leave it for an hour or two and come back and it will start fine, idle fine, etc. Not the starter or the battery (it's new).
One mechanic noticed no spark at one of the 2 ignition coils so I thought we had it nailed down but replaced it with a new one and still no spark. Car is sitting at a friends and I'll likely go back today and it'll start fine and run fine until the next time it decides to not.
Someone suggested the computer may be the problem. Suggestions? Going to try to reset the ECU today based on couple peoples posts that are different than what I'm seeing but may help.
Old 04-23-2017, 10:37 AM
PSmith67's Avatar
Did you ever figure out the problem? I'm having the exact same issue except mine won't start at all. No spark on 1 coil.
Old 04-23-2017, 02:21 PM
nmiller67's Avatar
We did it was the throttle body idle speed control valve. After figuring it out and replacing it we have been running fine for about a month now.
Old 06-09-2017, 02:08 AM
Alv's Avatar
Alv
Alv is offline
Crank sensor? Check. The wiring
davidsdlck
12-22-2020 06:51 PM
chicago3000gt
11-03-2010 02:37 PM
dcur069
09-09-2010 11:49 PM
oops129
01-04-2006 04:38 AM
lelliott
02-25-2004 11:29 AM
Quick Reply: 2002 Spyder GS No Spark on One Ignigtion Coil
