Crank but no start after changing plugs & wires
Old 04-03-2013, 10:29 PM
pinstripe's Avatar
Default Crank but no start after changing plugs & wires
I have a 2001 Mitsubishi Eclipse GT with the 3.0L V6 5 speed and just finished changing the plugs, wires, valve cover gaskets and upper intake gasket, I also put in a new battery. Paid attention while taking it apart and back together so I thought but now it won't start. The engine turns over fine, has fuel but not sure if it has spark yet. The OBD2 code says EGR transducer open or shorted. All connectors are connected as far as I can tell. Am I missing something with this EGR thing? Any help or pointers would be appreciated.
Old 11-16-2015, 02:16 PM
ricardohd91's Avatar
Check around the manifold, make sure you didn't catch a wire or something like that, could be causing a short in the EGR circuit. Almost all sensors require a 5 volt reference, so if that 5 volt is grounded, nothing with work.
Jonv420a
11-28-2012 03:19 PM
Jonv420a
11-28-2012 02:43 PM
boostedmuscle22
05-06-2012 02:06 PM
ehawk24
11-29-2008 11:31 PM
Tom97rs
11-12-2003 07:58 PM
Quick Reply: Crank but no start after changing plugs & wires
