Daughter's 2002 heat/temp.guage issue
While riding in her 2002 3.0 auto GT I noticed her temp guage would fluctuate between HOT and COLD and her heat would somtimes blow hot and cold as well.The car does not overheat though and otherwise runs ok. Would this be a sensor,thermostat, or something else causing this?
sounds like its low on coolant. have u checked the level?? if it is low, 2 common things leak coolant on that car. radiator splits at upper hose area, and the necks on the engine for the radiator hoses deteriorate and also leak coolant. again very common.
livetoride20000
01-03-2009 11:31 AM
