Grinding noise
Grinding noise
I have a 2000 v6 and there is this wierd grinding noise comming from the front driverside wheel. It really sounds like the rotor is grinding, but im not sure. It more or less happens when im accelerating, not so much when im coasting. You guys have any idea wuts wrong?
RE: Grinding noise
check the cv axel make sure the boot is not torn if it is than you may wan to replace the axel ir grease the crap out of it and see if it fixes it bu if it is already making noise it may be too late. also dose it make any sound when you brake if so you may just wanna check the pads?
