O2 sensor location & Idiot light replacement
Old 11-28-2009, 04:04 PM
LOWRIDER60's Avatar
Default O2 sensor location & Idiot light replacement
I need to know the location of the O2 sensor that throws the following code:
P0141 O2 SENSOR HEATER BANK 1 SENSOR 2
This is a 2002 Eclipse GT 3.0 with 86,000 miles. I know this thing has 4 O2 sensors and I think I know which one is the culprit as I unhooked each of them and ran a scan to determine it through process of elimination.
Also ,whats the best way to access the idiot lights on the dash? Underneath or can a dash panel be removed ?I believe my check engine light is burned out.
This is my Daughters car and I'm planning on fixing it when she comes home from college on her holiday break as the emissions test needs to be done by the end of the year.
Old 12-01-2009, 09:16 PM
westerlundjc's Avatar
Default here you go
here you go, i had the same problem that senso is located on the back side of the exhaust manifold closet to the firewall, if you go underneath the car to the rear manifold you will see it it is kind of in a tight spot you will need a 7/8" open-end wrench for that
good luck
Old 12-01-2009, 09:18 PM
Default dash light
the dash can be removed to replace the bulb, it is the easie way to replace the bulb just a couple of screws
Old 12-02-2009, 05:57 AM
LOWRIDER60's Avatar
Smile Thanks!
That was the one I suspected........................Also , thanks for the dash removal tip............................................
Maximus99
01-04-2008 06:55 PM
BrunoBoy650
06-05-2007 11:59 AM
hollyannaeree
05-09-2007 09:06 PM
paintballproam
06-28-2006 12:08 PM
antomx
08-16-2005 12:16 PM
Quick Reply: O2 sensor location & Idiot light replacement
