how to change spark plugs . HELP~~~~~~
Hi, everyone. I'm a noob here, and need some help`~~~~
I have a stock 2003 eclipse GT v6 , and i got 3 packs of NGK iridium spark plug.
Need to put them on, but I can only access to the front 3 of 6, the rest are hiding under the header(??dun know if that is the header~~)
Wanna DIY.Does anyone know how to change the 3 undre the header, or is there any guide for that?????
HELP~~~~~~~~~~~~~~~~~~
SOS~~~
SOS~~~
RE: how to change spark plugs . HELP~~~~~~
I see, but whatever that is, it stops me of meeting my dear last 3 spark plugs
Doese anyone can provide me a guide to take that thing off?
I googled it, but only find the guide for the model of 95-99
You have to remove the "Plenum" or "intake manifold" (whatever you want to call it, it's up to you, but it's not a header, that is on the exhaust side) and everything and anything that will keep it from coming out, plain and simple. After you remove it, the plugs will be very accessible. One word of caution, put rags in the holes or you may chance dropping something down them that shouldn't be there.
It's been too long since I removed my plenum, but it's very easy. It's a matter of you getting to it and stop being afraid of breaking something, lol.
The plenum gasket is also metal, so it's reusable.
One more note, buy a Haynes/Chiltons manual before doing any work on your car, it will save you a lot of headaches.
No worries MitsE03.
One more thing, don't remove the throttle body, it has a paper gasket and you will have to replace the gasket if you do, once you loosen the throttle cable adjuster, you should be able to remove the cable from the throttle body pulley...scary how quick this info comes back, lol. Plus I have pics of my old 6g73 (very similar to your 6g72, in just about every physical way).
That's about it really, the rest can come off without issues....just remember where they went...and don't crank down on the plenum bolts or it will crack! I believe the torque setting for them was something like 10ft lbs (don't quote me on that, it's been too long, look in the book first) and that's not very tight at all. It is tight enough to hold the plenum down and not back out though.
While you're there, look for leaks around the rear valve cover, they have this odd tendancy to leak when you least expect it too.
Again, it's a very simple task, it just looks scary. Go for it and you'll kick yourself in the butt for worrying about it at all afterwards, lol.
Have fun bud.
Have fun bud.
boriparamivida
09-24-2011 11:17 AM
MonteroSport702
03-13-2010 12:59 AM
bcolins
03-05-2005 08:44 PM
