Eclipse with a vr4
Eclipse with a vr4
i have a 2003 eclipse gts and its fast, but i want more power. i need advice on whether i should get a stage 3 RIPP supercharger for it or an egine swap for a vr4 twin turbo engine?????
I'd say the VR-4 i love those cars and even with a stage III supercharger, you will still lack the DOHC and other benefits from the VR-4, so if price isnt too much of an issue I'd say swap with the VR-4, mainly because turbos tend to crank out power and torque in the higher rpm band and superchargers in the low, and since the eclipse already has a powerful high end torque band, the twin turbos of the VR-4 would benefit the car greater by adding to the pre-existing power. only i'd watch the turbo fins carefully the VR-4's tend to get burnt fins on the turbos so make sure you check them thoroughly.
yea the 3000gt and the vr-4 engines are huge, they would not fit in the 3g engine bay without huge modifications.
that being said there has been 1 or 2 twin turbo 3g's gt's and several s/c gt's, it will probably be cheaper to s/c it, not to mention easier and less custom work
The the OP, Stop freaking posting hte same question more than once. We will answer you, as I did in one of your other threads asking this same question, which by the way you could have found out that the VR4 motor would nt work by useing a simple search on the web in 5 minutes
the GT and GTS version have the same engine... only thing that changes is the intake plenum and the GTS has ****ty pistons
