Sun Roof opening is stiff?
Has anybody encountered any sunroof problems? In my case, after I push the button to either tilt the roof or open it fully, nothing happens until I push up against the glass, then it'll slide open by itself. For some odd reason I have to push up against the class, sort of helping it with a head start or something. Anyone have anyideas?
RE: Sun Roof opening is stiff?
Could be a few things... though nothing factory caused, to my knowledge. The motor will only push so hard as to avoid blowing the fuse, when your pushing up on it, its allowing it to move freely. It seems like it may be stuck on something, or the motor is starting to go maybe. But like I said, the sunroof in 3Gs, while problematic, dont usually suffer from that issue.
Does it happen all the time? In my case it used to happen when the car was parked in the sun for extended duration. My mech suggested applying a very thin coat of oil to the portion of the roofwhere the rubber beading rests. Worked in my case....
