4th Generation This includes all Eclipses built in 2006 and 2007.
Mass Air Flow Sensor
Old 04-26-2011, 11:40 AM
Spyderkh's Avatar
Default Mass Air Flow Sensor
Sometimes the car starts - always when the open door light is on.
Sometimes the car wont start - always then the open door light is off - even though the door is open. Autoshop teacher say's it's a bad Mass Air Flow Sensor. - Any ideas ? Many thanks!
Old 05-04-2011, 03:50 PM
Serv_466's Avatar
y should that have anything to do...
If you had a bad MAF you would have a code. Check that first then if it does it all the time. Leave the car on and while it's on remove the MAF sensor and see what it does. Usually if the MAF sensor is bad, REMOVING the plug will not make a difference on how the engine is running.
2002Montero
06-06-2004 08:09 PM
1faseclipse
06-01-2004 12:25 PM
1rippinGT
04-02-2004 11:43 AM
ListenersAudio
02-22-2004 05:25 PM
Quick Reply: Mass Air Flow Sensor
