2007 Spyder GT Owner Satisfaction?
We bought a new 07 Spyder GT in late 06. In reference to this purchase I was wondering who out there has one and what they think of it. This car is the 6 speed manual. I'm sure the automatic is for some people, but the one we drove was doggy in comparison to the manual. Not trying to hurt the automatic folks feelings, just my experience. You've got to admit it's a looker. We went to a large new car showing and this wasTHE one for the wife.
My concerns:
1. Occuring at less than 200 milesis a transaxle noise in neutral with the clutch out.With the clutch in the noise goes away. This means it's a bearing in the transaxle, either the input bearing, the needle clusterwhere the main shaft fits in the back of the input shaft or the needle clusters at either end of the countershaft.
2. I noticed a lifter tick sometimes when it's cold. Started at about 1,200 miles.
3. I noticed that at times there's a puff of oil smoke, small but noticeable, when the engine starts. This would say that oil is getting by the valve guides. First saw it at less than 1,000 miles. Besides the factory oil, this car has and will be run on Mobil 1 synthetic. Do these 3.8 engines have valve seals?
This car is adult driven by my wife only. It's lucky if sees 4,500 RPM ever and rarely goes over 4 grand.
For $32, 000 US dollars I was expecting not to see any problems this early. The car now has about 6,000 miles on it. Other than these concerns it seems to be OK and is a lot of fun.
Thanks for the replies...Bird
My concerns:
RE: 2007 Spyder GT Owner Satisfaction?
For the most part, thats all going to occur atleast a few times while the engine is still new.
Its not really broken in until about 20,000 miles and you should expect odd little noises here and there.
But if it bugs you that much, take it to the dealer, its got a warranty.
No...Bearing noises don't go away. They only get worse. And brand new hydraulic followers shouldn't loose their prime. I'm fully aware of my warranty. None of this should be expected with any new vehicle. I was looking for replies from 07 GT owners.
Bird
Bird
Well... heres your first problem.... a good 90 of Eclipse drivers on this site don't drive brand new cars.
We are 2g people.
I'm fully aware of bearing noises.
You sure your wife is ok with the stick?
And like I said, if it bugs you that much, bring it to the dealer so they can do something about it.
Or, fix it yourself.
We are 2g people.
ORIGINAL: Texas Bird
My concerns:
My concerns:
the transaxle in that car is VERY large, VERY strong, and very well built. Its quite doubtful you will ever be able to damage it unless you actually attempt to do so.
Its built by Aisin, which is toyota owned. If you want to see a small snipit about it, go to their website here. Its the first transmission on the page, and its used by many, many car companies in many cars.
http://www.aisin.com/product/automot...etrain/mt.html
also, mobil 1 is truely not worth the money. Its usefullness is only of benefit with extraordinarily high or low oil temps, neither of which you will see with a normally aspirated engine in texes, especially if you "rarely rev to over 4 grand". despite what they may have you think, you absolutly CANNOT extend oil change intervals just because you're using synthetic oil. Thats a bunk myth.
the new eclipses are VERY, VERY reliable, and should give you years of trouble free operation provided you maintain it and dont take it to a racetrack on a regular basis.
Thanks for the replys. I won't address Mr. Tick as it appears he's still looking for Aurthur.
I will say Thanks to Manybrews. Admittedly, I do need to acquire more knowledge about the vehicle. Who would have thought an 07 anything would have had mechanical followers or pieces that would cause any valve train noise. I will say this valve train noise was at rest, at idle. I do need to learn about MIVEC. Interesting.
As far as the transaxle. I do hate to say I'm right. We had it back to the dealer with about 300 miles on the car and they said they couldn 't hear it either. Till they brought another brand new V6 stick up beside it and listened. I'm no genius, I just try to pay attention. Fact is that it's getting worse as time goes. I'll ride the warranty on this and have it tended tobefore it goes out.
The smoke I saw at start-up. It was oil smoke. Is the car burning oil? No. Just curious that you would see that. Yes, it could have been moisture, but it wasn't. I've seen it 3 or 4 times now. As far as your take on synthetic oil that's far too long a subject for me. I'll tell you that I agree with you in parts and disagree in others. I used to work in a unit that made PAO base stock(poly alpha-olefin). When it got on your hands you could wash them 3 times and still fell the slick on your hands. Amazing stuff. I do own a Ford 302 with close to 300,000 miles on it since the rebuild and have run nothing but natural petroleum based oil in it.
I do admire your loyalty to the brand. And not sure about the characteristic thing. I was raised onChryslers, but now have latent Ford tendencies. My first car was given to me in 1973 when I was 13 and was a Valiant with the mighty Slant 6.
Iworked on some of the first Mitsubishi autos in this country as I worked as a mechanic for Chrysler in late 79 and 80. The Chryslerfours were junk. If you wanted a good vehicle in that arena youbought the Chrysler product with the Mitsubishi engine or you bought thewhole vehicle that was a re-branded Mitsubishi. You should have seen the crowd of mechanics around that new tech front wheel drive in the dealership wondering how to get the transaxle out of it on a warranty job.
Bird
Bird
try this.. maybe it will help.
http://en.wikipedia.org/wiki/MIVEC
Bird
Bird
you shouldnt worry too much about your eclipse.. they're well built. Will it be 100 percent trouble free? Probably not. But out of the 39 cars Ive owned, none of them have been.
Hey ManyBrews,
Is'nt that almost the same, if not the same, 6spd thats also in the Corrola xRs, and the Matrix xRs?
Its a company thats majority stake is owned by Toyota, and those are the only transmissions that Toyota uses (the 6 speed in question here is not just used in an eclipse).
at least you didn't buy an older model then, i've had to make up new curse words while i'm working on my 2g. Plus all the great little quirks, like my cruise control.... works one day.. not the others..
Zequel
12-26-2014 01:40 AM
