What size speakers? - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 10-03-2004, 10:46 PM
Default What size speakers?
Hi,
I just got a used 1996 Mitsubishi Eclipse GS Spyder and the speakers in it are aweful so I am thinking of changing them. I have one question about the speakers - could anyone tell me what size speakers I should look for that will fit my car. I went to Best Buy today but there are so many different sizes. Could you recommend what size I should pick?
Old 12-02-2004, 09:55 PM
Default RE: What size speakers?
the rear are 6x9's and the front are somewhere between 6 and 7". The actual screw holes are 7 inches between the diagonal ones (top right to bottom left...) Check out crutchfield.com, they will tell you what will fit and they even provide free adapter brackets so you can use slightly different sizes.
Old 12-21-2004, 01:16 PM
Actually, the rear speakers are not always 6x9's my car has rounds in the back... but then again i dont have a spyder its just an 97 RS
Old 12-25-2004, 01:15 AM
hmmm, well mine on my GST are 6x9's in the rear, maybe they're differnet between years and/or models. The fronts in mine are 6 3/4" rounds.
Old 04-01-2005, 12:29 AM
SO how can i tell if i have rounds or 6x9. i got a 97 rs?
Old 04-04-2005, 02:28 PM
I'm pretty sure the 6x9's came with the infinity system, if you don't have that then you should have rounds in the back.
Old 07-15-2005, 02:10 PM
Good site I found was
http://www.mobiletoys.com/shopby/sho...asp?BRANDID=71
It will give you the specs for your speakers for different cars
Old 07-26-2005, 02:59 AM
i've never seen a 2nd gen eclipse with round in rear, but i heard it's easy to convert, and plus some say round speakers sound better. i'm big into audio quality, but i've never done a comparison.
Old 08-10-2005, 11:13 AM
i have a 99 gs 10th edition and i have round in the back also, they are the same size as in the front. i bought 6 1/2 full range RF for the rear but i had to drill new holes into the holder because i couldn't find ANY speaker that had the right holes. and then in the front i went with a Planet Audio components system 6 1/2' mids, and 1 1/2' tweets. however i had to modify the speaker holder in the front a lot to allow for the connections to work, so the answer to your question is 6 1/2 in te back and either 6' or 5 3/4 in the front.
Thread Thread Starter Forum Replies Last Post
6X9" speakers on 97 eclipse shamsulaswad Audio/Visual Electronics 11 03-18-2006 02:00 PM
99-03 front speakers lgary1978 Mitsubishi Galant 2 06-23-2005 11:03 PM
2004 Outlander LS front door speakers crunchie Mitsubishi Outlander 3 05-03-2005 04:21 PM
buzzing speakers (ground?) aswahdan Everything else 15 11-12-2004 11:25 AM
Endeavor Speakers? velcrobots General Mitsubishi Chat 0 11-15-2003 08:28 PM
Tags
1996, 1997, 1998, 2004, 2005, 6x9, 96, 99, eclipse, endeavor, mitsubishi, montero, rs, size, speaker, speakers
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
