Sponsored by:
Sponsored by:
2001 eclipes heating problum
Old 12-13-2008, 12:19 PM
Davids's Avatar
Default 2001 eclipes heating problum
The heater in my 2001 eclipes works ok when RPMs are up, but at an idel it cools right down. I just replaced the thermostat. that mad no differance. Does anyone have a suggestion were to go next.
Old 12-13-2008, 12:51 PM
dsm1990gsx's Avatar
Default RE: 2001 eclipes heating problum
How many miles are on the car and what did the coolant look like when you changed the thermostat?
Old 12-13-2008, 01:53 PM
Davids's Avatar
THe car has 125,000 miles on it. The coolant looked fine.
Old 12-14-2008, 08:25 AM
Manybrews's Avatar
the only thing that could cause that issue is a low coolant level, or a giant air pocket.
Old 12-14-2008, 09:59 AM
dsm1990gsx's Avatar
ORIGINAL: Manybrews
I was thinking the same thing, or possible flow problem.
Old 12-14-2008, 10:51 AM
Davids's Avatar
I will try perging the system of air. Would'nt you thing I would have over heating problums if there was a flow issue.
Old 12-14-2008, 11:12 AM
dsm1990gsx's Avatar
If the heater core is partially blocked it would give you issues at idle since the coolant isnt flowing as much as it would be if you were cruising at abt 3-4k rpms. Check the heater hoses that go to the heater core and see if there are hot to the touch.
Old 12-15-2008, 12:35 AM
Dusty Eclipse's Avatar
Out of curiosity, you ever get any liquid under the dash on the passenger side?
Old 12-15-2008, 07:21 AM
Davids's Avatar
No water under dash. I did check heater hoses, passenger side is hot the driver side is luke warm. I guess it looks like a heater core is in the near future.Any advise on this. I just did the one in my 2003 Dodge Ram. I had to remove the dash to get at that one, I am asuming this will be the same in this case.
NissanR34
08-27-2012 06:44 PM
mcam
06-05-2011 04:07 PM
ansar
06-01-2011 09:19 PM
Dmax6.6
03-19-2007 01:30 PM
jake88
10-16-2006 10:21 AM
Quick Reply: 2001 eclipes heating problum
