Sponsored by:
Sponsored by:
1990 Montero engine rotates -not firing
Old 01-31-2004, 09:24 PM
horine's Avatar
Default 1990 Montero engine rotates -not firing
My 1990 Montero's engine rotates but will not fire from the ignition. We changed the distributor, ignition coil, power module/ transitor and wires going from the distributor to the sparkplugs.But it still will not fire. The computer is good. The timing belt is ok, but no pluse or spark from the coil.</P>
Any idea where is the ignitor/ signal generator is located? Is it inside the computer? The manual shows it as a small box with 2 connectors. <IMG src=smileys/smiley6.gif border="0"></P>
Any suggestions would be greatly appreciated.</P>
Old 04-13-2004, 02:27 PM
check your alternator??.......check over all the wiring components
Old 04-13-2004, 02:49 PM
Are you sure its a spark problem and not a fuel problem? When you turn the key to the on position can you hear the fuel pump? If so do you have any pressure in the lines?
roundigo
11-11-2016 12:12 PM
oasis
01-23-2005 05:43 PM
morourke2@juno.
03-15-2004 01:53 PM
MonteroMofo
10-26-2003 06:32 PM
dbeaver
09-27-2003 09:51 PM
Quick Reply: 1990 Montero engine rotates -not firing
