Sponsored by:
Sponsored by:
Oil Leak
Old 10-14-2005, 06:30 PM
Limey's Avatar
Default Oil Leak
1997 Eclipse 2.0 Turbo. Have an oil leak, leaving a small amount of oil on the ground near front drivers side. I have cleaned the front of the engine, cannot get to the back. Oil appears to be coming from between the block & exhaust manifold....is this possible & if so what is the cause. Not blowing any colored smoke from tail pipe. If not possible, any suggestions where the leak is [8D].
Old 10-16-2005, 09:28 AM
wicked_outlander's Avatar
Default RE: Oil Leak
ORIGINAL: Limey
you need to replace gasket, also check your manifold fittings.
Old 10-17-2005, 12:17 AM
DSMTalonAWD51's Avatar
could be head gasket or jus the valve cover gasket
ccernst
01-14-2011 08:38 AM
TheRock0720
11-12-2010 12:30 PM
Mitsibitchi
01-31-2005 02:47 PM
darkman0127
07-09-2004 06:32 PM
OZ2003
11-26-2003 10:38 PM
Quick Reply: Oil Leak
