95 ECLIPSE ECU
Old 10-14-2005, 11:56 PM
badlarry's Avatar
Default 95 ECLIPSE ECU
Hey guys I'm buying a 95 eclipse and it needs an ECU swap. how intensive is this? and if it's over my head what does an install usually run. I'm really only a weekend mechanic.
Thanks
Old 10-15-2005, 06:09 PM
FireDoc's Avatar
Default RE: 95 ECLIPSE ECU
Disconnect battery, Unscrew plastic panel(I only had 1G's) whichever that may be, unbolt ecu, unplug, repeat steps in reverse. Thats it from the mechanical side. Try to leave your battery diconnected for 20 minutes or so unless someone here knows of any other quirks in the 2G's?
Old 10-15-2005, 07:52 PM
Hope you know the radio code when you unplug the battery... Or hope you have a aftermarket radio. Shouldnt be to hard to get out should be harder to find it in the first place.
Old 10-16-2005, 09:30 AM
wicked_outlander's Avatar
ORIGINAL: FireDoc
good to go...
Old 10-17-2005, 12:16 AM
DSMTalonAWD51's Avatar
its easy but the question how do you kno you need a new ecu?
JeremyMinton
06-06-2009 02:53 PM
nyc95gst
01-18-2008 01:25 PM
poiz
05-09-2006 08:14 PM
DR_NO
02-15-2005 12:04 AM
nikozai
01-29-2005 03:44 PM
Quick Reply: 95 ECLIPSE ECU
