Air Conditiong blows hot & light flashes...PLEASE HELP!!
RE: Air Conditiong blows hot & light flashes...PLEASE HELP!!
ORIGINAL: superinflamo
my car suddenly lost the freezing air, so me and my dad went to autozone and got a FREON recharge kit
its really easy, its just a can that has freon in it, and u connect it to the plug in the A/C plumbing
after that, cold air again!!!!!
idk if u still have the problem or not, and the can of freon with an adapter costs about $13
daniel
daniel
ORIGINAL: mattyblast
Unbelievable. They checked everything, and the only possible explanation they could come up with was that a magnetic relay of some sort in the clutch had 7mm of a gap in it, when actually it's supposed to have only 4-5mm to be into specs. Something like that. So they're going to replace the A/C clutch next week (that's not a part they stock, and understandably so).
daniel
daniel
ORIGINAL: dirtwagon
Forgive me for being ignorant, but what the hell is "idk" short for?
daniel
daniel
D=Dont
K=Know
ORIGINAL: dirtwagon
This won't always fix the problem though... I understand overcharging the system is a bad thing as well. Get a refill with a pressure gauge on it so you know you are within the appropriate range...maybe you'll need 2 cans, maybe you have other issues.
daniel
daniel
so if its 100 F outside the vents should blow out 80 F air? I dont think so, and I WOULD use the gauge, they are cheap enough now. They even make one that is like a tire pressure gauge, they are not that good of quality, but they do get ya close. Cold air in both of my vehicles is around 40F on a hot day, actually my truck gets colder than that at times.
ORIGINAL: Manybrews
Actually, that's probably right. If the compressor clutch gap (magnetically powered) is too large, the compressor will slip, thus causing the issue you were talking about.
