Steering column
Old 04-19-2007, 04:03 PM
Adam Ravesloot's Avatar
Default Steering column
Has anyone had any experience with the steering column in a Lancer detaching? The car still steers so it must be the adjusting mechanism but any experience or advice would be appreciated before the mechanic gives me a bid.
Thank you!
Dusty Eclipse's Avatar
Default RE: Steering column
Huh????
Old 04-19-2007, 04:05 PM
50ul }{4ck3r's Avatar
are you talking about the Plastic cover around the steering column
Old 04-19-2007, 04:43 PM
I believe it's the plastic around or something that controls the adjusting part of the steering column.....to move it up and down.
Ive never heard of those breaking... if it does... I doubt its an easy fix. It may be stealership time.
Old 04-19-2007, 04:45 PM
YA the stealership or a junk yard of heaven
Now it drops down and there is no control or locking when I try to move it back up or into place.
Old 04-19-2007, 04:47 PM
You may have to manually lock it.. have you like sat and screwed with it?
the leaver to adjust the height of it up and down...is that what your talking about
Old 04-19-2007, 04:48 PM
maybe someone broke it adjusting it...just find a junk yard or dealership
Quick Reply: Steering column
