Key locked in switch!!
okay, so installed the deck, now my key won't come out of the ignition switch, did the little tricks, nothing worked...starting to figure it might be a sort of current thats been shorted or something, not sure, im not so
RE: Key locked in switch!!
Try turning the key to on, stepoping on the brake pedal and putting the automatic shifter through some gears (no need to start the car). Return it back to park and then take the key out. The "shift lock release" that prevents the auto shifter from moving until a key is engaged and in the "on" position can fail, causing the key to be stuck in the ignition switch. Good Luck!
Joel, CA
Joel, CA
CeeMonetro
09-24-2012 04:22 PM
designflaw
02-24-2012 11:40 PM
monterosport57
08-10-2011 09:30 PM
Dumbo45
01-23-2009 09:29 AM
