Montero Sport blinking 4wd light
Old 08-12-2004, 12:14 AM
ole's Avatar
ole
ole is offline
Default Montero Sport blinking 4wd light
2000 Montero Sport keeps blinking the 4x4 light, and after 15-20min of driving the "ANTILOCK" lights up solid. By going into 4wd (also turns the 4wd light solid) or restarting the truck, the "ANTILOCK" light goes out while the 4x4 light flashes. Just had transmission flushed and differential fluid change. Could that have anything in common w/ problem? 4x4 engages and seems to disengage ok. Just the 4wd light flashes. And not flashing all the time, but getting to be more and more often.[sm=smiley35.gif]
Old 08-16-2004, 11:41 AM
ole's Avatar
ole
ole is offline
Default RE: Montero Sport blinking 4wd light
now blinks all the time.........
Old 08-16-2004, 11:47 AM
ole's Avatar
ole
ole is offline
Make it quit...[sm=icon_beat.gif]
Old 08-16-2004, 11:58 AM
so it works but blinks? regular blink or sperratic? is it throwing a code? antilock light should never come on... dealership.... sorry to say...
Old 08-27-2004, 11:35 AM
did it do it before you had the tranny serviced
Old 11-10-2004, 01:23 AM
Likely your freewheeling switch on the front diff is bad....unplug wire connection socket under vaccum can on Pass side wheel well....no more flashing or anti lock brake light coming on....switch is easy to replace and about 50.00 from dealer...
Old 06-17-2006, 08:07 PM
I had the same problem & unplugging that switch really does it. You access it by lifting the rubber flap right beside the passenger front tire, in the wheel well. Lift the flap in the middle of the well & you will see a canister about 7 inches long laying on its side. The switch is right in front of & at the base of the canister looking at it from the outside of the tire. Press down on the top of the left side of it to release the catch & pull it apart.
ole
19
06-10-2015 10:47 AM
2000MonteroSport
08-07-2012 04:15 PM
montero sport 2000
03-02-2010 03:42 AM
ultramindbrk
07-29-2007 03:07 PM
Bop
06-02-2006 08:07 PM
Quick Reply: Montero Sport blinking 4wd light
