Once again evaporator drain tube location!!!
Old 07-15-2007, 12:18 PM
bdcorey723's Avatar
Default Once again evaporator drain tube location!!!
I've spent over a week reading forums and different websites online looking for the evaporator drain tube for my 2002 Lancer ES with no help. I see that I am not the only person with the evaporator draining on the floor, has nobody ever figured this problem out? I am no longer a proud owner of a Mitsubishi product after all of the similar problems I have found online and no recall. It is BS! I am giving one last shot for a solution. Any help would be greatly appreciated. Thank you. Once again I only need the where abouts of the drain tube to unclog it, but do not feel like pulling the rest of the dash out as the first half was no picnic. My next solution is to pull the dash and drill a hole and run my own drain out of the evaporator box.
Old 07-16-2007, 01:34 PM
Manybrews's Avatar
Default RE: Once again evaporator drain tube location!!!
what exactly are you asking for? The position of the drain tube?
its on the bulkhead, slightly below halfway down, towards the drivers side. its NOT hard to see.
Old 07-16-2007, 05:23 PM
bdcorey723's Avatar
Thank you for the info. I was told on the passenger side and looked for an hour. I should have spent more time on the drivers side than I did. I will try again.
BassmanRuchy
06-01-2013 10:09 PM
ydna888
4th Generation
11-02-2010 10:21 PM
mckimro
08-23-2010 09:09 AM
hellsheep
08-07-2005 06:34 PM
monkey714
08-03-2004 11:31 PM
Quick Reply: Once again evaporator drain tube location!!!
