po300
Old 12-09-2006, 05:33 PM
xslim69's Avatar
Default po300
i have a ramdom missfire on a 97 gst. i have replaced 2 coil packs, plugs, and have msd superconductor wires, i also replaced the maf. im in a nut shell i dont know what could be causing the problen, i replaced all of the ignition system. i been trying to fix this proble for about 6 mounths. now
Old 12-09-2006, 06:07 PM
Manybrews's Avatar
Default RE: po300
have you checked compression? Correct timing? fuel pressure?
there are dozens of things that could cause a misfire. Why not get it professionally diagnosed instead of shotgunning parts at it.
also, aftermarket wires (like the MSD) are trash. Factory wires are definatly a much higher quality.
Old 12-09-2006, 08:49 PM
xslim69's Avatar
Default RE: po300
it is a brand new motor. yes it has the right fuel pressure, ect. o and when u run a msd ignition box (like i am) u need to run their supedcoductor wires. also the stock wires do the same thing.
gordonsen
08-24-2013 09:18 AM
jay_yrbrgh
02-04-2009 09:18 PM
Larimer522
01-31-2009 07:45 PM
Quick Reply: po300
