blow off valve??
The issue with some BOVs is that if they are not Diverter valves or recirculating valves they will cause idle issues and make your car run rich between shifts. I was running a open atmospher BOV for a while and my car was awful to drive. It would stall out if I pressed the clutch in quickly.
The two BOVs I listed above will not have a negitive effect on your car unless you hook them up wrong. The BOV that will Effect boost is the stock 03-05 GSR and RS BOV they are plastic and leak boost pretty badly. Your stock BOV is perfect for your car untill you want to run over 26 PSI or so
95HGeclipse
05-29-2006 02:26 AM
