Evolution 1-8 Turbo info
Got some of this info from a brochure. Some of this may have been posted here before but here goes:
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (steel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (steel alloy), Titanium alloy (RS)
Evolution 6
TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminium, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS/Rs2=Titanium alloy.
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
Evolution 1
Turbo = TDO5H–16G-7
Evolution 2
Turbo = TDO5H–16G-7
Evolution 3
Evolution 4
Evolution 5
Evolution 6
Evolution 7
Evolution 7 GTA
Evolution 8
EMonz57
Evolution Frequently Asked Question Section
12-08-2006 06:15 PM
ne0red
06-14-2006 07:31 AM
99galant
11-04-2005 02:01 AM
kenjiloc
08-10-2005 09:48 PM
