2003 montero limited 3.8L very hard to start
Old 12-18-2014, 01:55 PM
tonileila's Avatar
Angry 2003 montero limited 3.8L very hard to start
Hi all montero! I have 2003 montero limited 3.8L.It very hard to starts may be one minute for key rotation then starts if I give gas.When engine started the idling is very good and no fluctuation.
I did so far:
-new temperature sensor(every 2)
-new battery
-new starter
-new generator
-new fuel pump
-new fuel pump filter
-new fuel regulator
-new PVC valve
-new spark plug(6)
-injector clean(check fine every 6)
-fuel system pressure: 0 bar when ignition on
-fuel system pressure: 3.2bar (when engine works)
-throttle clean
-Mass Air Flow Sensor(MAF) clean
-EGR valve clean
-engine pass with scaner(Autel MaxiDiag Elite MD802)
-I put over the first fuel pump relay to the second fuel pump relay's space, than I put the second relay to the first relay's space. The car does the same as before.
HELP! What more can I do? Sorry for my small English language knowledge.
I'm waiting for answers and thank you forward.
My Email:seksarithy@gmail.com
Old 12-18-2014, 07:41 PM
up-and-down's Avatar
It could also be the type of fuel you are using.
Old 12-19-2014, 06:56 AM
tonileila's Avatar
95 gasoline for a long time
tonileila
06-16-2018 12:51 PM
tonileila
01-01-2015 02:29 PM
armymen
04-20-2012 11:39 AM
athineltlc
09-05-2008 09:51 AM
athineltlc
05-08-2008 12:16 PM
Quick Reply: 2003 montero limited 3.8L very hard to start
