99 Galant po300
Old 01-30-2009, 09:36 PM
Larimer522's Avatar
Default 99 Galant po300
Replaced valve cover gasket and spark plug tube seals. Tubes were oil soaked. Two weeks later got a misfire code (po300 random misfire). Replaced plugs and still have a misfire code after car gets to operating temp on freeway. Mainly after stop and go. Tach is also jumping around and sometimes dropping to zero.
Old 01-31-2009, 12:14 PM
dsm1990gsx's Avatar
Default RE: 99 Galant po300
Did you replace the spark plug wires too?
Old 01-31-2009, 07:03 PM
Larimer522's Avatar
I have not replaced the wires. I checked on them and there are only two. The other two cylinders are the coils. $75 for two wires and $107 per coil. I have been hesitent on replaceing due to price. If I was getting a po301,302,303, or 304 code? I would at least know if it was a coil cyl. or wire cyl.
Old 01-31-2009, 07:21 PM
dsm1990gsx's Avatar
Does it idle rough, check for vacuum leaks.
Old 01-31-2009, 07:45 PM
Larimer522's Avatar
No, It only has problems 7-10 miles down the freeway after it gets to operating temp. Cold and around town it is fine. Plus, isn't the tach. ran threw the coils? It is jumping around and sometimes stays at zero.
gordonsen
08-24-2013 09:18 AM
jay_yrbrgh
02-04-2009 09:18 PM
xslim69
12-09-2006 08:49 PM
DAVEMOTOR
01-04-2006 06:25 PM
BigSteve0034
05-20-2005 02:42 PM
Quick Reply: 99 Galant po300
