Code Po154, Po174
Old 07-27-2014, 02:39 PM
2001Mitch3.5XS's Avatar
Talking Code Po154, Po174
Hello all, I have my service engine soon light on now and took it to advanced auto to check if there are any codes and he came up with PO174 & PO154.
He tells me that it's the oxy sensor down stream... I have been doing some research on this matter and the net tells me that I have a Vacuum leak. Any help here would be great n tks for all your help here, Bob
Mitsubishi Montero Sport 3.5 with 128,000.
Old 08-17-2014, 08:56 PM
Slotho's Avatar
Hey Mitch, an O2 sensor is the only issue I have ever had on my 3.5, that was back around 60,000, I'm now around 125,000 as well. I don't remember the code, but that was problem. Lower right I think.. Any luck?
Old 08-18-2014, 01:00 AM
mxmikie's Avatar
P0154.....O2 Sensor Circuit No Activity Detected.......P0174.....System Too Lean
Old 09-21-2014, 04:24 PM
Default Fix for the codes here
I just replaced a completely dead battery and wolaaa, No codes are given now and the truck runs great. I am just wondering about resetting the computer or anything besides the radio code that I had to put in...
Old 01-02-2015, 06:51 PM
Is there a way that I can test the oxy sensors ???
I am getting like 8 codes now after the rebuild..
Old 01-02-2015, 06:53 PM
Tks. for the info.... Was it in the exhaust manifold cause the cd that I got online is just more of a parts list than anything...
Old 01-03-2015, 01:37 PM
UPDATE... Ok, Now I just ran some cataclean and some upper cylinder lube and reset the codes. Ran about half a tank out so far. Now the codes I get is P0174 Bank 2 system too lean, P0154 Oxygen circuit no activity detected bank 2 sensor 1 and P0401 exhaust gas recirculation flow insufficient detected.
Which one is bank 2 let alone number 1 ????
Old 01-04-2015, 03:53 AM
evan-e-cent's Avatar
See my post about P0173 error and oxygen sensors. I will also write a new post about OBD software (iPhone app) that lets you do extensive OBD2 testing, finding codes and resetting them without disconnecting the battery.
Old 01-04-2015, 03:56 AM
I just saw an ad on this page and clicked on it. Worth taking a look! It talks about electronic O2 sensor simulators and extension tubes.
O2 Spacer - Oxygen Sensor Spacer - CEL / MIL Fix - Oxygen O2 Sensor Adapter - O2 Sensor Extender
Old 01-04-2015, 06:08 AM
Very interesting Link evan I may have to look into something like that, I wish there was a way that I can test an o2 sensor but I guess I have to buy and replace and see if that was the problem... Tks.
Quick Reply: Code Po154, Po174
